Triple range vs Case-O-Matic
JMH1965
04-15-2003 12:27:51
Is a Case-O-Matic tranny worth having as far as dependability or should I look for a Triple Range?
I will be using it for mowing and utility work.
jls
04-15-2003 19:33:48
 Re: Triple range vs Case-O-Matic in reply to JMH1965, 04-15-2003 12:27:51
got a 611B c-o-m and I never had a case before but I like it, sweet for baling, and brush hogging; gets tuff just drop it down for a short while and pop it back up. Down side is if you have tender nerves they grind when you first try to put them in gear, ignore it and remember to drop the idle first, it still grinds just not as bad.
CASEPOWER
04-15-2003 19:13:40
I would think it is just like any tranny if it was taken care of it would be great. For loader work I would take the COM. Either would be fine for field work. Don't let anyone ever tell you there were flaws in the COM like the Ford SOS. I don't have alot of experiance with a COM, but I do with a Case Terramatic Drive which was a torque converter tranny like the COM use during the same 1960s period but used in the track machines and they are as tough as nails and you can quote me on that..
