David Brown 1200 Water Pump Woes
Mike
04-14-2003 10:03:09
Needed a water pump for the DB 1200, S/N 1200A 704835S, Diesel Eng S/N AD4/55A 5905. Took the pump to the local Case IH dealer who sent it out for rebuilding. I didn't get my original pump back and the design of the pump I got is different. The problem is that the original pump mated to the bottom of the thermostat housing with flat rubber washer. The new pump has a hose barb on the top...unfortunately there is nothing on the bottom of the tstat housing to connect a hose to. The local dealer is at a loss. Can anyone tell me: what p/n pump I need or is there an adaptor to allow the use of the new pump with the old tstat housing?
martin
04-22-2003 11:06:32
 Re: David Brown 1200 Water Pump Woes in reply to Mike, 04-14-2003 10:03:09
the part number of the pump you require is K952127 which is replaced by K262854. Should be available from your local case dealer
Elmer
04-14-2003 17:10:13
They sent you back a water pump for an old 990 with the AD4/47A engine. You need a water pump for a 990 with the 449 engine or the 1200 with the AD4/55 engine. I have one in stock if you're out of luck.
Mike
04-15-2003 05:09:40
 Re: Re: David Brown 1200 Water Pump Woes in reply to Elmer, 04-14-2003 17:10:13
Thanks. Pls send me an email with price for the w/pump. [email protected]
