Changing trans/rear end oil for 730?
birdatwork
04-14-2003 06:04:54
Does anybody know where the drain plug is to change the transmission/rear end oil? There are a couple what look to be like drain plugs(about 1 foot apart) on the under side about where the engine compartment starts, but this isn't on the lowest part of the rear end. Where these are is on the transmission which is kind of sloped up from the rear end. Does anybody know how much hi-tran it will take?
Also there is an oil filter on the upper portion of the rear end about under the driver's seat. Is this for the rear end?
I didn't find any other oil filters on my tractor. If this is for transmission oil then where is the oil filter for the engine?
Thanks
SHeiserman
04-14-2003 10:04:41
 Re: Changing trans/rear end oil for 730? in reply to birdatwork, 04-14-2003 06:04:54
The third drain plug is to the left of the drawbar (standing from behind looking at rear). It will take 18 gallons to refill. If you have CASE-O-MATIC you'll need 4 more gallons for that. The filter up by the seat is the hydraulic filter. Engine oil filter is is down by the generator. You need 9 quarts to refill w/filter.
ygdude
04-14-2003 11:23:19
 Re: Re: Changing trans/rear end oil for 730? in reply to SHeiserman, 04-14-2003 10:04:41
I have a 730 (8spd) as well.. do you have to drain all three plugs to change oil? or will the one at the back do it all???? Thanks!
SHeiserman
04-14-2003 20:03:04
 Re: Re: Re: Changing trans/rear end oil for 730? in reply to ygdude, 04-14-2003 11:23:19
To be honest I don't know, I pull all three.
ygdude
04-15-2003 05:12:11
 Re: Re: Re: Re: Changing trans/rear end oil for 730? in reply to SHeiserman, 04-14-2003 20:03:04
I looked last night. I didn't see anything under the belly on the left side or is it on the side of the casting? Have had a tough time getting the other 2 forward plugs out as well.
birdatwork
04-15-2003 05:17:08
 Re: Re: Re: Re: Re: Changing trans/rear end oil for 730? in reply to ygdude, 04-15-2003 05:12:11
I also looked last night and didn't see the drain plug on the rear?
case poor in pa
04-15-2003 16:40:00
 Re: Re: Re: Re: Re: Re: Changing trans/rear end oil for 730? in reply to birdatwork, 04-15-2003 05:17:08
that 3rd plug is kinda in front of the flat drawbar area to the leftlof it im thinkin i got 2 730s one 67 and a 62 both have 3..1 has eagle hitch other has that junk ball hole hitch. take all the plugs out you wants to see the pieces stuck to em dont ya just use a good socket ot wrench so you dont screw up the plugs.. that means NO vice grips boys ps ya have to be layin on your back in the mud to see the back one
ygdude
04-17-2003 04:54:46
 Re: Re: Re: Re: Re: Re: Re: Changing trans/rear end oil for 730? in reply to case poor in pa, 04-15-2003 16:40:00
would this 3rd plug happen to be on the back of the trans, below the PTO right above the draw-bar???? Thanks again for the info.
Roger
04-18-2003 13:12:32
 Re: Re: Re: Re: Re: Re: Re: Re: Changing trans/rear end oil for 730? in reply to ygdude, 04-17-2003 04:54:46
That's where our's is on an early 830, then there is a triangle shape cover to the right of that which is the hydraulic filter, remove the filter & clean it or replace it
