David Brown 995-Hydraulics
vic
04-14-2003 05:32:59
The hydraulic oil looks clean, however I have no idea what the filter looks like. I will change it, as well as checking the o rings. Can anyone tell me what the "switch" is on the right side of the tractor by the lift control? There is some writing on it that says "low external". Not really sure what it is for. Also, where do you set the draft control on this tractor for plowing?
Elmer
04-14-2003 17:14:54
 Re: David Brown 995-Hydraulics in reply to vic, 04-14-2003 05:32:59
I have manuals and parts that can help you out in any way. Feel free to email me. Elmer
James
04-14-2003 13:45:57
Welcome to the David Brown crowd. You obviously just got that tractor, and are probably not familiar with the workings of a DB. I first heard of DB a few years ago. I picked mine up from out in a field where it sat for 5-6 years. I went through all the things your are now doing a year ago. MY 995/6 has turned out to be a great tractor.
You have come to a great place for answers; however, let me be the first to suggest you get an owner's manual from your local CaseIH dealer. If you are not near one of them, I believe Elmer sells them(he can also ship you parts). The owners manual (and a repair manual if you have a lot of work to do) is well worth the money. I got lucky and found a repair manual on e-bay.
Good luck plowing.
Jens Andersen, Denmark
04-14-2003 11:09:42
The "Switch" located behind the liftcontrollever
is where you set the depthcontrol. To the left it
should say "depth" and is used for plowing.
In the midle it should say "height" and is used
for implement with wheels big enough to control
its depth. And to the right it should say "Exter-
nal" or T.C.U. and is used for external cylinders
like loaders, logsplitters dumptrailers. In this
position the liftlever must be moved ALL the way
back to bring oil to the outlets. The "Switch" can ONLY and I mean ONLY be moved with the lift-
lever ALL the way back.
Hopes this helps.
Jens Anderse ,Denmark
