Stuck L
04-12-2003 21:08:50
Last month one of my friends and I were trying to start my 1929 L that I just did a valve job on. We cleaned up the magneto and got it to fire but
by then it was low on gas so we parked it and ran to the filling station. When we got back (kess than 1/2 hour) we put 5 gallons in the tank and started down the street and the stupid thing
seized up on us. Now it will not turn over; this is the second time this has happened. Does anyone have any idea why?
Allan C
04-15-2003 21:25:42
 Re: Stuck L in reply to [email protected], 04-12-2003 21:08:50
Could be heat but does removing spark plugs help? I'm thinking a leakly head gasket may be giving you a "hydraulic lock in" a cylinder.
Tom Railsback
04-16-2003 06:27:25
 Re: Re: Stuck L in reply to Allan C, 04-15-2003 21:25:42
I already tried that and it made no difference.
One of my local friends said he had to pull the head on his L and then pull the rods and pistons and hone the sleeves. If I do that, I'm also going to put in new rings.
Thad
04-13-2003 05:00:12
This may sound stupid but let it cool and see if it frees up. I had a C that i got running after 20 years of sitting. Got it started and it had no rims to drve it so couldnt drive it . It ran fine could let it run hours and would do fine. Then i put on tires and drove it. It ran around my yard for a while then siezed come to find out the radiator wasnt circulating and would get to hot under a load. I went back a hour later she started right up hope this helps Thad.
