Hydraulics
Jerry Hall
04-12-2003 20:22:37
I have a Case 1270 Agri King tractor. I recently had the oil cooler worked on and now there is air in the hydraulics. Almost no steering. Is there a bleed line somewhere that I don't know about. The lift quit working right also.
Mike from Canada
04-13-2003 06:58:42
 Re: hydraulics in reply to Jerry Hall, 04-12-2003 20:22:37
most of the hydraulic systems ive seen are self priming/bleeding via the reservior breather. check to see if this is blocked.
check to see if the lines going to the cooler are seated properly. if the fittings are cross-threaded, dirty or loose, it may introduce air into the system
check to see if the cooler is free of obsructions. when it was rebuilt/repaired, passages may have been blocked.
or worse yet, check the pump. it may have failed you.
...oh yeah. check the pump if it has a bleeder on it.
may the force be w/ you.
mike
