Cracked head
Roger
04-12-2003 16:54:01
There was some talk on the forum some time ago about 430 diesel heads tend to crack if allowed to overheat. Where do they tend to crack? Can't find any on my head.
Mike from Canada
04-13-2003 06:20:56
 Re: cracked head in reply to Roger, 04-12-2003 16:54:01
if you are concerned about your head being cracked it may be too fine to see w/ the naked eye. if you go to your local machine shop and they will do a procedure called "magnafluxing" where they apply a stong electromagnet to your head (not the one on your shoulders) and dump some iron filings on it. the filings will outline cracks on the surface from the magnetic field making them visible.
not sure how much it costs but ask around. im sure if you've done all the work to dissassemble it (valves, springs, etc.) all they may do is clean it and check it.
good luck!
mike
