Wheel on a DC-3 case
Wayne
04-11-2003 08:48:49
I will probably have to move the rear wheels on a DC that I am hauling home this summer. Do they have a tendence to freeze up? Don't want to have to take my torch rig with me. The set up looks simular to other tractors that didn't me any trouble.
Thanks Wayne
jal-SD
04-11-2003 09:49:29
 Re: Wheel on a DC-3 case in reply to Wayne, 04-11-2003 08:48:49
Yep, they do have a tendency to rust to the axes. If the tractor runs, try loosing the bolts & driving it for a while. This will sometimes break them loose. If its not drivable, jack the tractor up, loosen the bolts, turn so the split is horizontal (this is important), SLOWLY let the jack down on the wheel. The weight should pop the rust loose. Oil the ax (under the hub as well as the underside of the hub generously) w/your favorite "schlicum". Raise the tractor, turn the wheel 1/2 turn & repeat the process. When you get it loose, keep the split horizontal, & "walk" the wheel in. Repeat on the other side. Worked for me. (My $0.02 worth. jal-SD)
Paul f
04-11-2003 09:46:20
Wayne: Short answer...take the torch, sledge hammer and biggest wrench/cheater bar you have.
I recently took my DC3 wheels off. They had not been off in many years. Getting the bolts loose on the hub center clamp took several rounds of soaking with PB Blaster and Kroil and several heatings with a propane torch ( I don't have a real torch) repeated attempts with a 1/2" drive IR air impact gun and finally beaten by using a 3/4" drive ratchet with a significant cheater pipe (don't tell Sears) The clamp blocks came off with a few hand sledge blows as did one wheel. The other one was more recalcitrant, finally had to drive a chisel into the key-way slot to get it pop loose (I had bad visions about getting the chisel stuck in there !!) There was significant corrosion on the axle shaft and inside of the hubs. Previous owner had used a variety of bolts for the hub clamps...most of them incorrect and all pretty badly corroded. New ones are $7.01 each (you need 8..ouch!!) at McMaster-Carr. If there is somebody near the tractor you may ask them to start spraying with PB Blaster (or the like) a few days before you plan to work on it. Also note there is a snap ring on the end of the axle shaft (to keep the wheel from working off the axle if the clamps loosen up). It was also painted/corroded in place and was too big for my snap ring pliers.
caseboy
04-11-2003 10:30:28
 Re: Re: Wheel on a DC-3 case in reply to Paul f, 04-11-2003 09:46:20
had many problems with moving rear dc centers that had never been moved. most common problem is the key sticking in keyway. best solution is lots of penetrating oil and large blocks of wood. a 4 foot 6x6 slammed into the edge of the cast center has lots of leverage power. also had to take another d case and put a wood cant between front axle and cast center. not too wise as when the center breaks loose the dc axle heads straight for the d grille. just remember to be safe and patient as you are working with brittle cast iron.
caseboy
Mike Schotte
04-11-2003 10:30:28
Hey Paul- I declare you winner the "word of the day" prize... don't think I've ever seen anybody throw around the term "recalcitrant" on this tractor board before! (grin) I like it!
-Schotte
(not being obsequious)
Dr Cy Kosis
04-11-2003 20:19:14
 Re: Re: Re: Wheel on a DC-3 case in reply to Mike Schotte, 04-11-2003 10:30:28
Me personally, I was way impressed with "Schlicum".
I'd say it was worth bonus points for instant clarity of meaning and added degree of difficulty of locating it in any edition of Websters printed so far.
Paul f
04-11-2003 12:34:08
Mike: I have to admit to two things...
One..Recalcitrant was not the word I used while I was trying to get the wheels off...the words used would probably get my message deleted and probably didn't help loosen the wheels but made me feel better.
Two.. I had to use spell check to get it right :-)
