Oil filter is always dry
jim
04-11-1999 17:35:39
I have two case VAC's and both have spin-on oil filters which never get any oil to them. Is there some bypass system that I'm not seeing or is the oil pump not working? I have used my 1950(the other is a 1948) for several hours at a time and have had no indication that there is an oil pump problem. I have blown out the tube and holes that the filter mounts over but that did'nt help either. HELP!!!
Craig L.
04-11-1999 19:47:37
 Re: oil filter is always dry in reply to jim, 04-11-1999 17:35:39
This sounds odd to me, but try to take the filter mount off the block, pull the coil wire off and crank the engine over unitl you build up oil pressure ( or untill you see oil running out). You may actually have an oil passage clogged in the block.
