Interference fit for bushing
Mike Lochner
04-10-2003 15:01:23
I need to remachine the bosses and press bushings into the lower boom of a 580B. Anyone know how much smaller than the bushing the boss should be cut?
Thanks
Mike
Mark
04-11-2003 06:30:32
 Re: Interference fit for bushing in reply to Mike Lochner, 04-10-2003 15:01:23
The rule of thumb for a press fit bushing is .0005 to .001 inch of interference per inch of diameter of the bushing. For example, a 2.000 inch bushing would require a hole of 1.998 to 1.999 inches.
This is assuming similar materials for the hole and the bushing.
Dennis/Ohio
04-13-2003 03:26:02
 Re: Re: Interference fit for bushing in reply to Mark, 04-11-2003 06:30:32
Hi Mark, Thanks for your input. I print and save such info for future use. I'm requesting your e-mail address to add to my file if you don't mind.
Thanks, Dennis.....
Bruce Nelson
04-10-2003 15:38:39
If you have a bushing that has been engineered exactly for this application, I would figure it like this. Measure the outside diameter (OD) of the pin that is made for it. Then measure the inside diameter (ID) of the bushing as it lays on the bench. Subtract the difference and add .003-.006" to this figure. This is will produce the finished ID you want, (FID). Next, measure the OD of the bushing, and subtract the difference between the ID and the FID that you had previously (ID-FID=x) This will be the size (x) you bore the hole, you want the bushing in. Typically these bushings go in at .008-.015 tight (interference), but if you use a bushing that is engineered for this job, and put it in too tight of a hole, the pin will be too tight. Hope this helps and is not too long winded, Good luck, Bruce
Dennis/Ohio
04-13-2003 03:36:20
 Re: Re: Interference fit for bushing in reply to Bruce Nelson, 04-10-2003 15:38:39
Hi Bruce,
I have welded and bored some of the bushing bores on my old 530 hoe. I had an interference fit more like what Mark mentioned. I don't know how I could have gotten them in with a .008 interference fit? Dry ice maybe? Thanks for your input, Dennis..... .
