Cluster gauge face plate
Greg Breisch
04-09-2003 02:16:19
Does anyone know who is refurbushing those cluster gauge face plates on these hundred series tractors. Have one that needs repainted.
Gary
04-11-2003 06:58:22
 Re: cluster gauge face plate in reply to Greg Breisch, 04-09-2003 02:16:19
well how patient are you? I just did my own if you can still see the numbers well make a copy of on a copy machine then go to a sign shop that makes decals. there is usally pretty many around.they will take that copy and scan your copy then put it all on a doubled adhisive wax paper. then all you need is to get the brown sray paint to match the background. then heres the patient part. you will use soapy water(not to much)then gentally peal one side of the wax paper off and place carefully then start smoothing out the water.you may use a hair dryer on low. just peal the wax paper off take your time watch as the lettering stays in place. some may move on you just use a toothpick to replace! the only thing I did not do is the eagle unless you know an artist! when you go to the sign shop they will give you plenty of pointers! I am very pleased with mine! good luck!
John Saeli
04-09-2003 05:52:35
Hey Greg, Haven't talked in a while. I have temp. gauge assy's that you inquired about at one time, and I have the names & #'s of 2 places that might be able to help you out with that face plate. 315-585-9826. Hope I can help, John
DON L
04-09-2003 04:53:57
I used to know of a man, that had aother guy do them, but the man who did them got ornery doing it and quit. I may know of a place that could make new ones..... .?????
Don L.
