Vac
Doc in IA.
04-08-2003 08:24:46
what could cause noise in tran. just in 3rd. and rev.
Mike from Canada
04-09-2003 01:10:41
 Re: vac in reply to Doc in IA., 04-08-2003 08:24:46
the reverse idler and 1st/3rd gears are in constant mesh so when one or the other is engaged, and is noisy something is worn. check teeth, splines, clearance on the shaft, bearings, shift forks and the oil. most of these procedures require splitting the tractor so book a weekend off.
good luck!
mike
