NO oil pressure on 210B
Mike Johnston
04-07-2003 15:56:04
The oil pressure is virtually non existant on this 210B I've been fooling with. The manual says that insufficient pressure should not be corrected by using shim washers under the relief valve spring, but that is the only way TO do it if a new comparable spring cannot be found. Is that a correct assumption? Has anyone tried bumping oil pressure by using a shim washer?
Thanks for any suggestions.
Mike Johnston
C. Amick
04-08-2003 09:23:35
 Re: NO oil pressure on 210B in reply to Mike Johnston, 04-07-2003 15:56:04
Is the oil pump not pumping enough or are your bearings completely shot? I don't think you will gain much if the problem is with the bearings. Are you getting any oil to the head?
Mike Johnston
04-09-2003 08:36:40
 Re: Re: NO oil pressure on 210B in reply to C. Amick, 04-08-2003 09:23:35
I haven't pulled the valve cover yet to look, but highly doubt oil is getting up there. I pulled the oil-to-guage tube off and cranked the engine. After 12-15 seconds, there still was no oil coming out. The bearings sure may be shot by now.
Mike
C. Amick
04-09-2003 10:07:59
 Re: Re: Re: NO oil pressure on 210B in reply to Mike Johnston, 04-09-2003 08:36:40
You also should pull off the oil filter and make sure the vertical stem is still there that sprays oil up inside the filter. Without this stem to restrict flow, all the oil will only go up to the filter housing and back down into the oil pan.
Dennis/Ohio
04-07-2003 16:41:53
Hi, I dont know what your pressure should be but I wouldn't be suprised if normal pressure was 20 psi at full rpm with warm oil. You can shim an old spring but usually they just colapse until you have no spring and its like a solid piece of tubing. I dont know why a spring for a 148 or 159 wouldn't work.....Best wishes, Dennis.....
Jim M
04-07-2003 16:36:05
The book I read said not to use washers but to renew the spring by streching it back to orginal length. I have done this several times. Also beware that those oil pump are bad about shearing the internal woodfruf key. The book says its not seviceable but I have replaced several of those keys.
