New vs. used piston/cyld
INCase
04-07-2003 11:14:46
Is it worth putting in a set of used piston and cylinders vs. buying new kits. Does anyone sell new kits that are single cyl sets instead of the 2 cyld sets I've seen???? thanks
also what is good source for new/used grills (730)
DON L
04-07-2003 18:02:43
 Re: New vs. used piston/cyld in reply to INCase, 04-07-2003 11:14:46
John makes a good point. But don't forget the salvage yard[ or whoever] that took the tractor down for any other reason. I have seen a many good sleeve and piston go by. Not new , but good stuff. Or the tractor puller guy who has put in the BIG stuff, has the good take-outs. Either way, new rings and a valve job go a long way , with the part you have.
Don L.
John Saeli
04-07-2003 15:52:49
Hey INCASE, You have to ask yourself, "Why did the previous owner of those sleeves & pistons replace them with new in the 1st place"? Are you talking gas or diesel? Personally, As long as I'd have to pull the head, I'd replace both, if not all 4. I can get you 1. John
