Will a 12v battery hurt anything?
Steve-IA
04-05-2003 09:36:47
Hi all,
I need some advice. I'm using a 12 volt battery on my 49 LA. Besides the lightbulbs, will I damage anything? What about the hourmeter, ammeter gage, starter? What's it take to convert?
Any advice would be appreciated.
Thanks,
Steve Moeller
dave
04-07-2003 22:11:26
 Re: Will a 12v battery hurt anything? in reply to Steve-IA, 04-05-2003 09:36:47
I sure would not want a butt chewing but I have had 12 volt batteries in a dozen or so tractors for probably 20 plus years. As of today the only thing I do is unhook the generator. You would be surprised how often you can start a tractor on 12 volts before recharging the battery. I have probably 5-6 that I did not even unhook the generator--just adjust them for max voltage if you are concerned. One AC has a resistor on it as it had it on when I purchased it. LIGHTS ARE A NO NO FOR SURE. good luck Dave
Steve-IA
04-08-2003 20:11:55
 Re: Re: Will a 12v battery hurt anything? in reply to dave, 04-07-2003 22:11:26
Dave,
Nice to hear you haven't had trouble. I'm going to try an 8v since they are available. But I'll keep my 12v handy if that 8v doesn't work(or for cold weather) & not worry so much about busting anything. It sure starts fast on the 12 right now. Makes me wonder if a slow start on 8v or a quick start on 12v is better.
I'll try both & report back:)
Thanks,
Steve
Steve-IA
04-07-2003 20:14:43
Hi all,
Excellent discussion with some really great information. The LA starts really well now but did not start well the first 6 months last year after 20 years of storage. I'll check the flywheel & bendix for any wear but I think I'll try an 8 volt battery anyway for kicks since they are still available. Dad ran an 8v on this thing & it was never fully charged. I'll probably have to adjust the spring in the VReg like mentioned. At least now I know why.
If this 8v doesn't work I'll have a REALLY cheap battery for sale in a couple months!
Thanks for the info!!
Steve Moeller
Kennyp
04-07-2003 07:29:20
This was a great discussion. I just wanted to add that when I ran a 8 volt battery it gave me about as much problems as going to 12 volt. the voltage regulater had to have the spring tighted a bit to charge and every time you mess with a VR, its usually problems. 8 volts gave me great head lights...until one night one light burned out, then 30 seconds later the other. Had to make it to the end of the field in the dark. The engine was overhauled with bigger bore, higher compression and the 8 volt did work where the 6 volt would not spin it..
Allan C
04-06-2003 16:01:59
We ran an LA on 12 volts for a while and ended up cracking the casting on the drive end from the bendix slamming in. I don't know, of course, if this was bad luck or a real problem. You don't have to do anything to the guages if you convert. Just the lights, a 12 volt regulator and generator, or, if originality isn't that important an alternator with a built in regulator is the best. With an alternator you'll have to go neg ground, of course but all that requires is to reverse the connections on the ammeter.
Steve-IA
04-06-2003 08:56:41
Thanks for all the feedback everyone. This helps a lot. It does start really well luckily. Did not think of the Bendix & flywheel. I may try putting a 6 volt battery on. Not sure if anyone sells 8 volt any more, but I'll look.
Thanks again!
Steve Moeller
Mike from Canada
04-06-2003 22:18:17
 Re: Re: Will a 12v battery hurt anything? in reply to Steve-IA, 04-06-2003 08:56:41
8V batteries are still available. check w/ NAPA or your local farm supply/ tractor dealer. the only difference is the posts are on the same side (like a 12V) instead of opposite corners and theres 4 cells instead of 3. they are available in roughly the same dimentions too.
good luck!
mike
Steve-IA
04-08-2003 20:04:59
 Re: Re: Re: Will a 12v battery hurt anything? in reply to Mike from Canada, 04-06-2003 22:18:17
Mike,
8v at Fleet Farm are $44(520 CCA) & NAPA is $65(550 CCA). You're right about the posts being on 1 side like a 12v. My new battery cover from Don L. will have to be raised up:) Very glad to know I can get an 8v. Think I'll try it.
Thanks for the advice!
Steve Moeller
Steve-IA
04-07-2003 19:54:00
Mike,
Thanks for the info. I think 8 volts may be the way to go. My LA has 4000 hours & I'm sure it turns over a tad easier than when it was new. (Although it sure the heck doesn't seem like it when I try it by hand:)
Steve Moeller
L. Lamp
04-06-2003 15:14:04
I had the starter for my '54 SC rebuilt and when I took it in I told the rebuilder I was going to convert to 12 volts and asked if the starter could take it. He said no problem,all 6 volt starters are designed to operate on 5 to 17 volts without stressing them out.
Eddie in Ky
04-05-2003 16:39:18
The starter too will have to be changed, sooner or later, if you have to use it much. It will also make the starter bendix hit the flywheel harder as they engage. This will, over a period of time, wear on the flywheel. How long all this takes depends on how often and how long you have to crank it each time you start it.
Jim P
04-06-2003 21:12:55
 Re: Re: Will a 12v battery hurt anything? in reply to Eddie in Ky, 04-05-2003 16:39:18
I run my 48 LA for 20 yrs. on 12 volt and never had a bit of starter problem. Grinding it slow on six or 8 volts is a lot harder on it than 12. Like anything it can have problems but has nothing to do with 6 or 12.
Paul Janke
04-06-2003 08:03:12
I agree that 12V on a 6V starter is more harsh while engaging, but I have never seen trouble because of the higher cranking voltage. I have often wondered if the wear might actually be less because the higher cranking speed means fast starts, therefore less total cranking. Just an opinion, for what it's worth.
John Saeli
04-05-2003 13:33:24
Steve; The started & amp guage will be ok. Lights, hourmeter, gen & reg. will have to be changed. John
Slowpoke
04-06-2003 23:05:18
 Re: Re: Will a 12v battery hurt anything? in reply to John Saeli, 04-05-2003 13:33:24
Most of my old '40s-'50s hour meters are labeled "6-24 volts". They are just a clock that is wound every 6 minutes by an internal solenoid.
rick
04-06-2003 08:15:22
Or you could step down the voltage for all the gauges and anything else that needs 6 volts. That's simpler than changing all the gauges, and cheaper too. We used to convert WW II army trucks into fire trucks, and we always changed them over to 12 volts. worked well and boy did that 6 volt siren screem! Wish I had one of those truck
