Electrical system of Case
vac tractor
Bud
04-03-2003 23:52:39
I'm restoring a Case tractor as a FFA Project. Well I took over when the tractor was all tore apart, so I don't know how the electrical system should be. Where can I find a layout of the electical system for a Case Vac???
Frank
04-04-2003 18:16:36
 Re: electrical system of Case - vac tractor in reply to Bud , 04-03-2003 23:52:39
Theres a parts manual on ebay now. # 2521123323
Bud
04-04-2003 22:24:17
 Re: Re: electrical system of Case - vac tractor in reply to Frank , 04-04-2003 18:16:36
Thank You! This really helped me out. Bud
Mike from Canada
04-04-2003 00:36:04
its pretty simple. i used the CaseIH parts manual. there is a little bit of difference between coil ignition and magneto ignition. which one do you have?
mike
Bud
04-04-2003 06:22:38
 Re: Re: electrical system of Case - vac tractor in reply to Mike from Canada, 04-04-2003 00:36:04
Mike,
Wow that was fast!!
I'm restoring a 1947 Case - Vac. If you have the book showing this could you scan it and e-mail that to me?? I would really appriciate it!!!!!
If not is there some place online to find it??
Thank You, Bud
Mike from Canada
04-04-2003 06:40:58
 Re: Re: Re: electrical system of Case - vac tractor in reply to Bud, 04-04-2003 06:22:38
unfortunately, i dont have a scanner. my old computer has little wooden buttons and the body of the keyboard is made of stone. Fred Flintstone would be proud.
you can probably order one on-line (you may need it anyway) from this site. look under "marketplace" in the left hand margin and click on "tractor manuals".
yeah. i work at a factory on afternoon shifts mostly so when i get home late i log on to see whats posted. frightens a few people that im actually up that late.
good luck!
mike
