Case VAC or VAC-14?
Joe Fabregas
04-10-1999 18:31:16
I have a Case VAC, serial 5459753, adjustable wide front end, Eagle hitch. Should I order the VAC Service Manual or the VAC-14 Service Manual? Can we tell from the serial number? Any help appreciated. Thanks, Joe Fabregas [email protected]
Toolbox
04-15-1999 19:23:46
 Re: Case VAC or VAC-14? in reply to Joe Fabregas, 04-10-1999 18:31:16
Joe, You've got a 1950 VAC. Order the VAC manual. Your tractor is same as mine. There seems to be a fair amount of VAC's in the world, but I've only seen 2 tractors from 1950 with Eagle hitch and adj. wide front.
Thanks, Joe-
04-11-1999 06:35:36
Thanks for the input. Just afraid to shell out $30 for another book I can't use. So far looks to be a plain-Jane VAC. JoeFabregas [email protected]
TMAC
04-10-1999 20:51:36
By your serial number, I believe you have a '51 model. The easiest spot check for a "-" model is the hood release. It will have a push/pull hood release on the front of the hood shaped something like an egg.
Dug G.
04-11-1999 00:17:48
 Re: Re: Case VAC or VAC-14? in reply to TMAC, 04-10-1999 20:51:36
Also, some of the VAC14's will have a 14 designation before or after the serial number.
