More CC Questions
Steve
04-02-2003 16:10:27
My dad has a 1930 C and a 1937 CC. On the C the spark plugs point into the head at a 90 degree angle, while on the CC the plugs enter the head at an angle downward. Another difference, the C cranks real easy, and the CC is a knuckle buster. I am guessing low comp vs. high comp head? My dad has not opened up the engines on either one, both run good and don't smoke.
Just curious.
Steve
SmartAxe
04-04-2003 09:17:38
 Re: More CC Questions in reply to Steve, 04-02-2003 16:10:27
The head with the plugs sitting flat at a 90 degree angle sounds like the low compression head that was standard on the C and early D series (part # 4570). The part number isn't visible until you take off the valve cover.
The head with the plugs angled downward sounds like a later model head from a D series (possibly a 5505). The part number should be cast into the side of the head on this one. The engine blocks are pretty much identical so the heads are interchangable.
-Mark
Brian in Ohio
04-02-2003 19:54:30
That is a DC head. My 1938 CC has it's originalhead, and the plugs are at a 90 deg angle like my C.
Has anyone else seen a CC like mine? It has a factory road gear in it. Wind it all the way up, and it will do about 40 MPH...
Brian in Ohio
04-02-2003 19:54:04
Brian in Ohio
04-02-2003 19:53:05
RoyG
04-02-2003 16:18:08
At sometime a DC head has been put on the CC
Okla/Kans Bill
04-05-2003 20:03:27
 Re: Re: More CC Questions in reply to RoyG, 04-02-2003 16:18:08
yup thats whats happened. Ive changefd out the wjole CC engine with that from a DC. Works good. Someday Ill have top change out the flywhee;l so I can use the starter
