What does draft-o-matic mean?
birdatwork
04-02-2003 05:23:55
What is draft-o-matic? My Case 730 comfort king says draft-o-matic on the side.
I have also seen case-o-matic. What is that?
Thanks for the help.
Jim Handke
04-02-2003 06:06:05
 Re: What does draft-o-matic mean? in reply to birdatwork, 04-02-2003 05:23:55
The first three point hitch case made was the eagle hitch. Draft arms were rigid and depth control was adjusted on the implements. Then came the draft-o-matic. The depth was set with the control lever and the control valve kept that depth under various load conditions.
John Saeli
04-02-2003 09:52:32
 Re: Re: What does draft-o-matic mean? in reply to Jim Handke, 04-02-2003 06:06:05
Right you are Jim. Advertising back at that time said the Draft o Matic actually sensed the load at 600 times per minute. On a hard pull it would raise the iomplement somewhat and there was a control to shut the sensing off or make it more sensitive. John
GeoMo
04-03-2003 05:18:33
 Re: Re: Re: What does draft-o-matic mean? in reply to John Saeli, 04-02-2003 09:52:32
John, could you explain the setting of the draft control? Which position does what?
