DC-3 Zenith Carb Adjustment Help?!?!?
Chris Hibbert
03-31-2003 10:16:51
Can anyone give me detailed adjustment instructions for my Zenith carb? I especially need instructions on the high speed adjusting screw (the one on the bottom)
Thanks in advance.
Paul f
03-31-2003 14:56:45
 Re: DC-3 Zenith Carb Adjustment Help?!?!? in reply to Chris Hibbert, 03-31-2003 10:16:51
Chris: Close needle valve (finger tight only!) open 1 to 1 1/4 turns. Tractor should start and run. Once she is warmed up bring her up to full throttle. Then open valve further until speed drops (over rich). Close valve slowly and it will speed up then finally start to stumble (starvation) This gives you the operating range. Best running is slightly past max rpm toward the rich side. Real key is to run it for awhile and put her under load. If she hesitates to pickup power under load richen it a little more.
Paul f
