Help Case DC
Tom B
04-10-1999 16:36:25
I just bought a 1950 case DC and was going to change the oil & filter. When I took the cover off that says OIL Cleaner there is no filter in it. It has a screen at the bottom and a 1" tube coming up the center. Is there suppose to be a filter here or just the screen and if there is what kind of filter. Thanks from a rookie.
Rich H
04-11-1999 12:48:58
 Re: Help Case DC in reply to Tom B, 04-10-1999 16:36:25
The oil filter is canister is above the starter. Take a look at:
Link
It shows the oil filter canister above the starter and the two oil level check plugs.
Tom B
04-10-1999 18:31:14
The thing I took apart is above the starter. There is nothing on the otherside that I can see.
Aaron
04-10-1999 21:01:58
 Re: Re: Help Case DC in reply to Tom B, 04-10-1999 18:31:14
Well, that would, in fact be the oil filter. Why nothing was in it is a good question. To find the air filter unit, just follow the air cleaner pipe down. Big cast iron square thing, if I remember right.
Aaron
Aaron
04-10-1999 17:46:59
You took the oil bath air cleaner apart. The oil bath cleaner sucked air into and back out of the oil and this cleaned the air. Think the oil bath air cleaner is on the left side under the steering arm, the oil filter is on the right side, above the starter.
Aaron
Mike
04-10-1999 16:59:23
You may have taken apart the oil bath air cleaner. The oil filter in a DC is in a round container about 4-5" in diameter with a nut on top to remove the lid. There should also be a small pipe plug in the bottom of the canister to drain the filter before opening the lid. If I remember the oil cleaner housing is on the left side of the block when looking at it from the radiator.
