Help me identify by engine # the Case tractor I aquired
John P. Martine
03-30-2003 14:49:49
I think it's a VAC but can not be certain. The serical number tag that Case screwed on just below the instrument panel is gone. Looks like it's been gone for over 25 years according to the man I bought it from. He believed it to be late 30s early 40s. The engine serial number is FA1248267. Where can I go to match up the engine # with an approximate year manufactured. Additionally, this Case appears to have Desert Sand color on all of the sheet metal. Did Case use this color BEFORE the 60's? If it will help in identification, I can provide digital pictures. I bought it from a man in MN last October 31 and its taken this long to get it to my home using the fine and super people that use the Hauling Schedule. I want as much info as I can get. This tractor supposidly worked the Canadian farm land, retired to a lake property in Northern MN for the last 25 years and was parked and replaced by a modern tractor 5 years ago. I want to give her a new life. --JPM
CASEPOWER
03-30-2003 18:09:49
 Re: Help me identify by engine # the Case tractor I aquired in reply to John P. Martine, 03-30-2003 14:49:49
It is a VC and could be a 1940 41 or 42. If I were to guess I would say a 1941 because they made 8160 that year and a total of 12462 in the 3 years. The engine is a Continental 124 cubic inch and was also used in the massey 101 junior. Case hired the tranny out to Clark. If you can check the PTO shaft and see what size it is it will help tell the year. If it's 1-1/8 it is before April of 1941 and if it is 1-3/8 it is after. One of the reasons the V series was redesigned into the VA series was that Clark could not provide enough gears for the trannys. Also the flat heads were not very good for running on kero..
John P. Martine
03-31-2003 17:34:49
 Re: Re: Help me identify by engine # the Case tractor I aquired in reply to CASEPOWER, 03-30-2003 18:09:49
I measured the PTO shaft. It's 1-1/8 inch from inside of notch to inside of notch. Now, I'll go back to the color of the paint on the sheet metal. This Case looks to have been brush painted once upon a time. All of the sheet metal appears to have a nearly white (surely well weathered and faded by now) color of paint. I ask again, did Case use a desert sand like color on these model of tractors in this period ...'40 & '41? I bought a parts manual for the Va Series. Since Casepower believes its a VC, is the VA book useless to me? Also, is the VA IT Manual of any use to me with this tractor? --JPM
CASEPOWER
03-31-2003 18:30:32
 Re: Re: Re: Help me identify by engine # the Case tractor I aquired in reply to John P. Martine, 03-31-2003 17:34:49
First the paint issue. No they did not use anything but flambeau red unless it was military or industrial then it could be yellow or green. The PTO should be measured from the outside of the spline so it would be the later model. Your VA series books won't help you because there are very very few if not no parts that interchange. I am not sure what color primer they used but thats what you could be seeing. Your tractor is either a late 1941 or 1942 model.
Steve in PA
03-30-2003 16:24:22
The pictures that Mike posted are of a VC. That was the predecessor of the VAC. The years that you were given are consistent with that model as well. I can't help with the exact year using the serial #, but I'm sure that someone will be able to on here. Casepower might be able to help. I hope that this helps a little at least.
Photos of John's Tractor...
03-30-2003 16:09:27
Here are some pics that John e-mailed me. The quality isn't very good after enlarging them... but maybe you VAC experts can see what you need to see:
REAR VIEW-
third party image
FRONT VIEW-
third party image
Check out the trailer hitch on the front...
-Schotte
John P. Martine
04-23-2003 10:46:27
 Re: Re: Help me identify by engine # the Case tractor I aquired in reply to Photos of John's Tractor..., 03-30-2003 16:09:27
third party image
Forget the engine bit! notice in the pictures that there is a stripe of chrome trim on the engine cover along ech side of this tractor. Of all of the restored tractor pictures of Case VAC's (and I'm not implying that this is a VAC)none have the chrome trim. Can anyone identify the model of Case I have. I do not have a serial number tag. It was lost years ago ...not by me. I've got a real puzzel on my hands and all printed information, internet web sites on Case do not give me hint. --John P. Martine
John P. Martine
04-23-2003 10:46:11
third party image
KEN FRITSCH
04-02-2003 01:03:53
John: I RECENTLY COMPLETED A 1941 VC THAT WAS A GIFT FROM A NEIGHBOR AFTER A LITTLE TLC ( STUCK VALVE) AND SOME PAINT & TIRES IT BECAME THIS NICE LITTLE TRACTOR THAT IS FUN & PRACTICLE TO DRIVE & USE FOR OUR SMALL FARM CHORES BEST OF ALL IT WAS NICE ADDITTION TO THE WINTER GAS UP FOR THE ANTUIQE TRACTOR SHOW HOPE YOU HAVE AS MUCH FUN WITH YOURS PLEASE FEEL FREE TO E-MAIL IF YOU NEED TO --THANKS KEN
