Case-d-c
Herbert Brady
03-29-2003 07:27:29
Would like to know if someone could tell Me where I could find out the apprx. value of this tractor if I described it to them. Herb.
John Saeli
03-29-2003 13:49:05
 Re: case-d-c in reply to Herbert Brady, 03-29-2003 07:27:29
Herb; Describe it here, several of us will attempt to put a value on it. John
Herb Brady
03-30-2003 01:23:27
 Re: Re: case-d-c in reply to John Saeli, 03-29-2003 13:49:05
D-c case needs paint also one rear tire and one front tire. runs good,tin good,and seat bad. Year unknown.
SmartAxe
03-30-2003 07:26:19
 Re: Re: Re: case-d-c in reply to Herb Brady, 03-30-2003 01:23:27
Herb, The description is a bit vague, but here's my opinion on worth. First, a complete and running DC rig should start you at least at 5 bills. You said the tin is good so I'm assuming no major dents, rust or rust holes, which should be worth another 1-200 if the tin is straight, fenders are there and they're not rusted out. A seat assembly can be had, but knock off 25-50 because you gotta go find one. No cool points for tires since it appears you'll be buying new rubber for it all around. Does it have the Eagle Hitch (Case version of a 3 pt hitch)? If so, add another 150-200 provided it's in good working order. Above all else, LOCATION, LOCATION, LOCATION.. The value is all subject to the are of the country you're in. If the DC Case was a common tractor in your area, the above is a ballpark figure. If the DC was not a common rig in your area, multiply the figures above by 1.5 to 2 for a good ballpark figure.
It really depends on how much it's worth to you and how much you are willing to spend on it. Check for the serial number on the dash plate to figure out what year model it is. If the dash plate is missing, the SN is stamped into the flange on the left side of the tractor where the engine bolts to the tranny. Good luck.
-Mark
Herb Brady
03-29-2003 07:30:35
