New Engine Breakin
KyCase
09-26-2006 20:16:48
I Just overhauled my 1070 case. Can anybody tell me what is the best way to break the new engine in. (complete overhaul top to bottom)Thanks for the help.
Walt Davies
09-27-2006 10:28:48
 Re: New Engine Breakin in reply to KyCase, 09-26-2006 20:16:48
Well now that you have read all the notes you must be thoughly confused.
It has been a long time argument over how to break in a new engine. The newer engines need a much short time to break them in than the older engines did. In the olden days they were pretty much slapped together and hoped that they would last till they were borken in. the tolerances were not all that close. I have seen some so tight that you had to pull them to get them started. Now we are much more inclined to build them to the tolerances that are far closer to what they will be after many hours of hard running. We use bearing that are set at factory setting for a new engine and these are set so as the new engine will run right out of the box. The rings are seated best under back pressure rather than under aheavy load. it is recommended by almost all car comapnies that you vary the speed of the new car for the first 500 miles then drive as you would under normal conditions. 500 miles at 60 MPH would 8.3 hrs. I think 50 hrs is over kill I don't hardley put that much on my working Kabota in month of haying. I would think that the first 10 or so hrs would be more than enough to get the part seated. Remember we are not using bearing made from babbit and hand trimmed to fit we are using factory made bearing that are perfect to the fit for the new engine. Also there are not any loose pieces of metal that fall off as we run the newer engines so we don't have to worry about that stuff anymore. I would just run it up and down a good road with a high hill and let it back pressure down the hill a few time to seat the rings keep an eye on the oil pressure and temp and after about 10 hrs use as you normally would. One thing never run a tractor engine at slow engine speeds while working thye are made to run right up against the governor for best performance.
Walt
KyCase
09-27-2006 08:12:51
Thanks for the info everyone. The tractor is used mostly for bushoging with a 10 ft. bushog so I dont think over loading will be a problem. Thanks again.
INCase
09-27-2006 05:50:46
How did Case break in new engines when they built them?
dboll
09-27-2006 05:04:31
warm it up , check for leaks, retorque heads and reset valves, then work it, DON'T LUG it! lighter at first then gradually increase the load.
John Saeli
09-27-2006 09:51:29
 Re: New Engine Breakin in reply to dboll, 09-27-2006 05:04:31
Doug & I agree on re-torqing the heads. Case shop manual says to back the bolt off 1/4 turn, then bring it back up to torque. Using the pattern. I've always found that if I just re-torque without 1st backing it off, that the bolt won't budge. However, after backing it off the 1/4 turn, it will come back that 1/4, then come on around another 1/2 to 3/4 before you reach torque. What's that tellin us? Always oiling the threads is a must too.
dwag
09-27-2006 17:12:40
 Re: New Engine Breakin in reply to John Saeli, 09-27-2006 09:51:29
You can "get away " with that procedure on a lower hp eng like a 1070, but don"t try it on a 4690 or bigger green tractor. Backing off the head bolt is an invitation to a blown hd gskt. Better just to retorque by pulling head bolt a little tighter with a breakerbar.
John Saeli
09-27-2006 18:07:02
 Re: New Engine Breakin in reply to dwag, 09-27-2006 17:12:40
Only difference between the 1070 & 4690 block is the bore. We did our 4690 that way. Hasn't blown a gasket yet.
noncompos
09-26-2006 23:00:11
Welll...there's two schools of thought on breaking in newly overhauled engines...
School A: take it slow and easy, watch for leaks, listen for worrisome noises, put some hours on it before beginning to load it, gradually increase load over week or so if everything goes well...
School B: Take it out, cram the heaviest load you can on it, pour on the coal, everything'l seat better under load than by babying it like a puss of some kind...
Unfortunately, the two schools seem to be mutually contradictory....
(Personally, I lean toward "A"). With symapthy, good luck.
Roger (Mi)
09-27-2006 02:51:53
 Re: NO substained heavy load! in reply to noncompos, 09-26-2006 23:00:11
The best way to seize up your newly rebuilt engine is to put it under a substained heavy load. The tolerances in a rebuilt engine are tight and generate a great amount of heat. A heavy load adds to that heat. The compounded heat thins the oil and causes premature wear and may seize the engine. Don't do it! Hastings Manufacturing has its own idea on how to seat a new set of piston rings. In a car, put it in second gear, accelerate full throttle. Do that twice, and the rings are seated. You could put the 1070 in 4th gear, 1st range and full throttle twice. Obviously, don't keep it at full throttle. From that point on, loads on the engine can gradully be increase. Have at least 50 hours on it before any heavy plowing.
TomfromPa
09-26-2006 22:09:52
Go out and plow or run a feed grinder
El Toro
09-28-2006 07:45:16
 Re: New Engine Breakin in reply to TomfromPa, 09-26-2006 22:09:52
That's what I did after mounting the plow. Hal
