Vac ring gear
Crank
03-27-2003 05:59:51
Can the ring gear be taken off & reversed on the flywheel? Tractor is A 1950 case vac. Many thanks, Crank.
Mike from Canada
03-29-2003 07:23:54
 Re: Vac ring gear in reply to Crank, 03-27-2003 05:59:51
should be ok. just heat up ring gear evenly w/ a torch (not too hot. you dont want to crack it!) and grab the egde w/ a pair of vise grips and when it expands just flip it over. used to do it all the time at a garage i used to work at.
