Front wheel alignment for a 1950 CASE VAC wide front.
Myron Stickley
03-26-2003 16:53:58
Does anyone know how to properly aligned the front of a 1950 CASE VAC with a wide front?? I have a 1950 CASE VAC which was originally a row crop, but now has an after market type wide front end. The turning radius is very large. The problem is that the front tires do not maintain constant alignment with each other during turns. The wheels are in alignment when straight but the angles between the wheels increase disproportionally as the steering is turned from left or right. The tie rods come out the front of the tractor to turn elbows on each vertical king pin, which are aligned perpendicular with the wheels. Any help is greatly appreciated.
mj
03-26-2003 17:37:29
 Re: front wheel alignment for a 1950 CASE VAC wide front. in reply to Myron Stickley, 03-26-2003 16:53:58
Can't you trim the 'stops' to make it turn tighter?
myron
03-26-2003 17:10:24
CURRECTION: ELBOWS ARE PARALLEL WITH WHEELS NOT PERPENDICULAR. Thanks
