Engine timing (or at least make of engine) 580c Backhoe
Steve S.
03-25-2003 21:22:44
Lost fuel timing pulling injector pump. Are the marks (crank, cam, etc.) visible through the small front cover? Is there a hole for a timing pin in the crankshaft or flywheel or something similar?
I HAVE to get this thing going by 3-27, so any help would be greatly appreciated. Thanks,
Steve.
Max
03-26-2003 19:08:01
 Re: engine timing (or at least make of engine) 580c Backhoe in reply to Steve S., 03-25-2003 21:22:44
No pins required for timing. Just line up the timing marks per the model number of the injection pump. 8� BTDC on early models and 0� on A151113 pumps and after.
Woodbeef
03-26-2003 04:03:14
The Case 580C has a Case built 207 c.i. engine.
