Mag conversion
JDT
03-25-2003 14:39:53
Looking at an LA with a mag.What will it take to convert to a Distribitor?
Brad Wies
03-25-2003 23:20:35
 Re: Mag conversion in reply to JDT, 03-25-2003 14:39:53
Hi, it can be done. Get a mag from a Farmall H or M and it should work. On my old DC-4 the mag was rusted up and I couldn't seem to find a good one so I bought a distributor for 30 bucks. If you use the tractor everyday I would opt for the distributor, better spark IMHO, but a mag is nice if the battery is dead or you use it for show. Honestly, go for the mag, if no luck finding it, go for the distributor.
Good Luck
-Brad Wies
I repectfully disagree,,,
03-26-2003 02:18:45
 Re: Re: Mag conversion in reply to Brad Wies, 03-25-2003 23:20:35
Brad,
A flangemount H4 magneto from an International H or M would fit onto a DC ('cept for the early models), and it would fit on an SC, too... but the LA was always equipped with a base mount magneto up until the end of production (I believe.)
I suppose you MIGHT make an International E4 mag work on an LA, but I don't know for sure.
Robert Kelly has always told me that these "big" Slick/Case magnetos for the LA's are the HOTTEST mags of all the ones he's collected- easily sparking a 3/4" gap. I doubt a distributor/coil setup could do that...but I must say that I'm not an expert on distributors.
My vote is to keep the magneto. Yes, parts are scarce- but I think the big Case ones have a better chance of being fixable than the little Case ones like the 4JMA and Type 41.
Regards, -Schotte
Brad Wies
03-26-2003 13:53:42
 Re: Re: Re: Mag conversion in reply to I repectfully disagree,,,, 03-26-2003 02:18:45
Hi Mike, I didn't realize the mageto mounted differently.
I meant to make it sound the magneto is the better way to go with a distributor as a last resort.
I believe Case made a good magneto, it is just hard to find a cheap one if your in a jam. I used a distribuotr because everyone wanted an ungodly amount of money just for a magneto.
-Brad Wies
laipuller
03-25-2003 19:54:14
it can be done, might not be pretty on a show tractor, but does real good on my puller. i did not make it myself, but it is rather easy. personally if you are restoring i would stick with the mag. email me if you want details but unless your pulling and need the dist for electronic ign. i wouldn't
Will
03-25-2003 17:24:30
Why?
CASEPOWER
03-25-2003 16:50:54
From what I have read all LA series even the late ones had a Mag. I don't think a DC distributor mount and gov. will fit in it. Anyone ever tried???
John Saeli
03-25-2003 17:16:00
 Re: Re: Mag conversion in reply to CASEPOWER, 03-25-2003 16:50:54
Hey CASEPOWER, Shame on you for even suggesting putting a distributor on a CASE. Putting a distributor on a CASE is like putting perfume on a hog. You just don't do it. John
CASEPOWER
03-25-2003 18:47:03
 Re: Re: Re: Mag conversion in reply to John Saeli, 03-25-2003 17:16:00
I know John, but, but, but,well he ask..
