LAI? I'm not sure
Zonie
03-24-2003 22:20:08
I took a look at a case tractor today, I belive it is a LAI, I couldn't locate the ID tag, but then I have no idea where to look. this tractor has a cast iron radiator, it has a massive loader on the front built by Lull (I think that is what it said) this tractor has huge counter weight on the back. it has an industrial type front end with really massive rear break drums. The loader bucket looks to me to be about 2-3 yd bucket.
This tractor will run by squirting starting fluid into the intake, I'm assuming the carb, tank and lines need cleaning.
Is the LAI a chain drive and if so is it something to watch out for problems?
Other than the carburetor problem this tractor appears to in decent shape, tires are pretty cracked but still usable.
Hydraulics seem to work.
Anyone have an Idea of it's value?
and one last question, are there any problems getting parts for this tractor?
thanks,
John
Gene Dotson
03-25-2003 16:53:00
 Re: LAI? I'm not sure in reply to Zonie, 03-24-2003 22:20:08
Zonie; With the cast iron grille, I would be more inclined to beleive it is a DI. The LAI would likely have a stamped grille like the LA. I have a VAI with a Lull loader. Sure is a heavy unit for this little tractor....Gene
Brian in Ohio
03-25-2003 06:41:16
I used to own an LAI, and one of the tell tale signs is the front axle is reinforced with what looks like a truck axle spring. The one I had was used as an aircraft tug, and had a one ton wheel weight on each side of the dual rears. The serial number should be stamped on the driver's left side right where the engine and transmission come together.
CASEPOWER
03-25-2003 04:52:34
If it has the heavy hubs made into giant brake drums it is a LAI. I would guess anyway. Also a lot of LAI and DI units had the Lull loaders. Don't let them chains in the rear scare you away. There less prone to having problems then bull gears and it has been proven that they transfer power better then gears. Just like any other loader tractor check for cracks and breaks in the castings of the tractor, but if it's a LAI it was built to handle the loader. It worth at least as much as your willing to pay. To you anyway.
Zonie
03-25-2003 07:17:33
 Re: Re: LAI? I'm not sure in reply to CASEPOWER, 03-25-2003 04:52:34
Thanks for the information, anyone have any idea how heavy this tractor might be ?
Steve-IA
03-25-2003 18:12:56
 Re: Re: Re: LAI? I'm not sure in reply to Zonie, 03-25-2003 07:17:33
Hi,
My LA with loaded rear tires is 8100. I just paid $2,250 a yr ago to get mine back into the family after 20 yrs. It's also in great shape with no major repairs, so it's worth it to me.
Good luck!
Steve Moeller
Joel
03-25-2003 07:58:05
I pulled my LAI a few years ago, so I'm not sure on this but its got to be in the ballpark. I believe it weighed in around 8400. No weights.
