1030 pto
Kevin Roberts
03-22-2003 06:13:02
I am looking at a 1030 case and the dealer tells me it has 1000rpm pto only. I had a later model (1983) 1390 and it had 540 and 1000, all you had to do was flip the shaft over. I was wondering if dealer was possibly wrong or not. If not, can it be converted? It seems to be pretty cheap h.p. and pretty clean tractor. Any advice, pros, cons, or opinions appreciated. Thanks Kevin Roberts
Mike
10-08-2003 14:49:33
 Re: 1030 pto in reply to Kevin Roberts, 03-22-2003 06:13:02
No you don't have to change the whole back end.Just a matter of a couple of gears inside.We threw on a 830 housing onto our 1030 just to make things easy..
Chris Reinmann
03-23-2003 20:40:03
It's not a big job to change , you do have to change the whole pto unit, will take 2 to 3 hours, but it will well be worth it. A good 1030 is a heck of a tractor around 105 hp. They are easy on fuel, and hold up very well, if taken care of. If you over load them they will run hot and crack the heads. Hope this helps.
bob
03-22-2003 20:50:22
You have to change the complete unit off the back end. If you can find a 540 pto unit for sale its not a hard swap. Just like rebuilding a pto clutch in one. There is some people looking ofr the 1000 ubits and a few looking ot change them to 540 also. You might be able to find some one willing to trade with you. We have 3 1030 2 930 and 1 830 all are 540. Never had a 1000 on the farm till i bought a 1855 oliver the last fall. All things considered the price of older 1000 equpiment forsale at auctions made me wonder about getting a 1000 to just beable to get cheaper deals at sales. Where are you located at? I can get you a 540 unit if you decide to get the 1030 with the 1000
Kevin Roberts
03-23-2003 11:52:38
 Re: Re: 1030 pto in reply to bob, 03-22-2003 20:50:22
Thanks for the info. How big of a job is the changeout? Also wondering how these tractors were on fuel? I have heard they were pretty easy on dsl, but that's only hearsay. Any other opinions appreciated, still thinkin it over. Bob, if I do get it,I'll be sure to contact you if your still interested-I'm located in N.W. MO. Thanks again,K.R.
kydavid
03-22-2003 16:45:12
That's why they're cheap, 1000 only. Have to change the whole backend (or use an adapter and run engine at 1460RPM)
