990 david brown
DAVID
03-20-2003 17:18:27
on a 990 the 3 pt. lift wont lift a round bale of hay. It will lift about half the weight but wont clear the ground with it. Pump pressure is 2200 psi and the loader on front work fine. Is there a by-pass or pressure regulator for the 3 pt. lift? Also the tractor wouldnt move till I changed the filter.Any help is appreicated. David
Elmer
03-22-2003 04:36:17
 Re: 990 david brown in reply to DAVID, 03-20-2003 17:18:27
The lift piston in the cylinder may have a bad seal.
