DB tachomrters,ELMER need info!
JOHN WEAVER
03-19-2003 10:25:40
Elmer, I asked you one time on this discussion board if you could fix a tach and you said no. My hour meter is still registering hours but the tach needle goes nuts. You said you might possiblly have new aftermarket tachs. This is a1972 990 selectamatic.Let me know if and or what might be availale, thanks ,JOHN
Elmer
03-19-2003 16:55:37
 Re: DB tachomrters,ELMER need info! in reply to JOHN WEAVER, 03-19-2003 10:25:40
You may have a bad tach cable. If your needle is bouncing that tells me you may have a frayed cable which makes it flex and twist in the outter casing. I have them too and i can get you tach reasonable too. Take the tach cable off at the engine end and pull the innner cable out and inspect it.
