L Case
LP
04-07-1999 17:55:37
Hi I was wondering if anyone could provide the following information on the model "L": How much do they weigh, what horsepower are they, what is the 1st gear speed, what is the difference btw the L and LA?
Thanks
Harold H
04-07-1999 19:35:06
 Re: L Case in reply to LP, 04-07-1999 17:55:37
LP,
The L on steel in Nebraska test yielded 47.04 belt hp and 31.94 db hp. Weight as tested was 5300 pounds. The L on rubber yielded 47.04 belt hp and 40.80 db hp. Weight as tested was 8025 pounds. The LA gasoline Nebraska test yielded 58.53 belt hp and 51.68 db hp. Weight as tested was 10,755 pounds.
Harold H
R.M. in Ont.
04-07-1999 19:16:38
The weight depends on whether the L is on steel
wheels, cut down steel to rubber or was built with
rubber tires. A friend of mine has a 29 L that
weighs 5000lbs even. Not sure of the weight with
factory rubber but should be well over 6000lbs
H.P for an L in good shape would be 50+ on the belt.
The LA used the same engine but used a 4 speed
trans and the flambeu red paint job.
lp
04-10-1999 08:35:27
 Re: Re: L Case in reply to R.M. in Ont., 04-07-1999 19:16:38
Thanks for the info boys!
