How hard is it to use a cultivator on a 1948 Vac tricylce tractor?
Nicholaus Sowde
03-14-2003 20:15:38
How hard is it to use a cultivator on a 1948 Vac tricylce tractor? How hard is it to put on? I don't know whether it is hand lift or hydralic or what. How much do you usually see them go for? I can get two sets for a 1948 Vac and the other came with a 1952 Vac-12 for $50 for both sets. Thanks alot for any comments at all
ff316
03-16-2003 20:19:26
 Re: How hard is it to use a cultivator on a 1948 Vac tricylce tractor? in reply to Nicholaus Sowder, 03-14-2003 20:15:38
My 49 has hydraulic cultivators. There is a lever on the right of the dash with a linkage running down around the belt pulley, that's the lift/drop lever. If you need any pictures get a hold of me, it may be a few before I could get out to the farm but I could proabably get some eventually.
Fireman
Miss Grundy
03-16-2003 03:11:00
Real Hard
schultz47
03-15-2003 18:35:18
I used to cultivate corn with a VAC. I had cultivators on the front and back, connected by a rod to raise them. The back cultivators mounted on the eagle hitch, the fronts in the diamond shaped brackets on the front. HTH
Jerry
03-15-2003 14:18:30
Hi,I remenber my dads Vac 1951 that had culivators on it. They raised by the eagle hitch with a rod that ran from the front to the back lift arm. The bracket is still on the tractor. It took dad and I to set them on the front,the rest was easy.I hope this helps.
Frank Bessler
03-15-2003 08:33:18
I have a 52 Case VAC three wheeler narrow row crop and it came with the cultivators on it. I have both hand and Hyraulics. Have picture of tractor with them mounted and also have The "E" series Master-frame and CULTIVATORS manual for the "VA" if you need a copy.
Okla/Kans Bill
03-15-2003 17:52:20
 Re: Re: How hard is it to use a cultivator on a 1948 Vac tricylce tractor? in reply to Frank Bessler, 03-15-2003 08:33:18
Ray, if you are counting the tall handles that set near the rear axles, one on each side, those arent lifting handles, those are adjusting handles. And as to the other post, GOOD LAWD A GRAVY. Im 56 and I put on DC 2 row cultivators by myself every year. I could probably out on VAC cultivators with one hand lol
John
03-15-2003 11:30:22
If I may be a pain, I would also love a copy! I have a 1950 with the side cultivators in the barn. I am currently restoring the tractor and was planning to mount them when I was done.
