DC-4
Tom
03-14-2003 06:24:03
My tractor has started to use lots of oil but doesnt seem to be burning it.. Anyone have any ideas?????
L.Lamp
03-14-2003 07:27:27
 Re: DC-4 in reply to Tom, 03-14-2003 06:24:03
If it isn't burning oil its leaking oil. There must be an oily mess somewhere. Start where the motor bolts to the transmission. Engine oil circulates through the clutch housing. If that joint is loose or the gasket broken it will use lots of oil. Also check the mag flange gasket. It has to be oil tight too. Clutch shaft seals, inspection plates right and left. If you are new to Case, check plug at bottom of clutch housing, it may be loose or missing.
