VAC hood
Tommy
03-12-2003 06:49:49
I've just acquired a 1951 Case VAC (VAC 5571992)with a bad hood. A friend has offered me a hood off his parts tractor. They look the same but they are different. His has a top latch and mine does not. Mine appears to have had a post of some kind on top of the grill area but no holes on top where a latch assembly would be. Also mine has a flat area about 2X2 on the very front with 2 vertical holes.Can anyone tell me what's going on?
Thanks,
Tommy
JERRY
03-12-2003 16:14:44
 Re: VAC hood in reply to Tommy, 03-12-2003 06:49:49
Tomm, My dads VAC 1951 has the hood latch on top ,you pull the lever and it unlatchs the dawg that holds it to the grill. hope this helps
Jerry
Duane(Pa)
03-12-2003 10:34:38
They (Case) changed the hood design in 51' You'll need a Late Hood, The grilles are different too. The hole you describe is where the new style latch goes.(front center) push to release hood latch
Tommy
03-12-2003 12:05:15
 Re: Re: VAC hood in reply to Duane(Pa), 03-12-2003 10:34:38
Hey Duane, Thanks for the info. I really appreciate it.
Tommy
