Installing hydraulics on DI Case
Tony in Maine
03-11-2003 16:06:12
I just purchased a DI case and would like some input from anyone who might of added hydraulics to their DI case. I have a DC back in Nebraska, at my folks place, that I took a hydraulic pump off a combine and put it between the mag and the block . I also thought of mounting a belt driven pump. I might want to build a three point for it to plow with. Any idea would be much appreciated. Thanks
Mark S
03-16-2003 13:19:24
 Re: Installing hydraulics on DI Case in reply to Tony in Maine, 03-11-2003 16:06:12
Tony, My DI has a centerfugal hydraulic pump on the front of the tractor direct drive from the crank shaft. It is factory with my Hough Loader. You cannot put the hydraulics that are usualy on the back of the transmission of a D or DC since there is a shaft for the brakes that goes across there where the pump usually sits. If you want a three point hitch I would go with a DC-3 or DC-4 with Eagle Hitch. You could probably trade your DI for one as DIs are hard to find. Hope this helps.
Mark
C. Amick
03-14-2003 14:46:35
I'm not that familiar with the "D" series. I'm presently putting hydraulics on an SC. Does your DI have the chain driven shaft inside rear housing below the PTO shaft? I'm using this shaft which runs off the PTO shaft to run my hydraulic pump on the SC.
03-11-2003 19:53:23
I don't see why that wouldn't work. A D Series engine is a D series engine, whether it's on a D, DC, or DI. As long as you have a flange mount magneto, you can put the combine pump on it. That would be a lot less work than finding a factory hydraulic set-up on a junker and changing it over. Good luck.
