Valves For 251 Cu. IN. engine
Gene
03-11-2003 13:42:49
Does any body know where we can get valves for this 251 cu.in. engine, that we are working on? The machine shop that is doing the heads said he can't find any valves. The exhaust valves are pitted bad and if he grinds them, he doesn't think they will hold up. Thanks Gene
Don L.
03-11-2003 14:12:53
 Re: Valves For 251 Cu. IN. engine in reply to Gene, 03-11-2003 13:42:49
A 251 was made in a gas and diesel. Which do you have?
Gene
03-11-2003 18:13:17
 Re: Re: Valves For 251 Cu. IN. engine in reply to Don L., 03-11-2003 14:12:53
We have the gas model? Sorry I didn't list that before. But I understand that the gas and diesel are the same engine. I guess the valves are different. As you can see I'm not that good with engines. Thanks Gene
Duner Wi
03-11-2003 19:09:42
 Re: Re: Re: Valves For 251 Cu. IN. engine in reply to Gene, 03-11-2003 18:13:17
Rings, rod brgs. and main brgs. are the same according to my catalog. Valve guides are different as well as valve springs. Valves are not listed in my catalog.
Gene
03-11-2003 19:16:21
 Re: Re: Re: Re: Valves For 251 Cu. IN. engine in reply to Duner Wi, 03-11-2003 19:09:42
Thats true with the book we have and also the machine shop that told my friend he can't find any valves for it. That's why I'm trying to find a place where we can get them. Thanks for the info. Gene
John Saeli
03-11-2003 18:42:03
Gene; I have a complete set of valves for a 251 gas. John
Gene
03-11-2003 19:08:33
 Re: Re: Re: Re: Valves For 251 Cu. IN. engine in reply to John Saeli, 03-11-2003 18:42:03
How much you asking for them, so I can tell my friend. John thanks for the info. Gene
