Finding make and model
Rick
03-10-2003 20:27:32
I have found a 6 digit code on my old case. It was on the tool box. Is this the right number to find the year? or is there another somewhere else? 331420 then you would take the 1st and 4th digit together and then subtract 3 from it and you would get the year. Being a 1931. Any help will be greatly appreciated.
Brian
03-11-2003 07:25:34
 Re: finding make and model in reply to Rick, 03-10-2003 20:27:32
Depending on what model you tractor is, that should be the serial number, and you are correct of it being a 1931. There should be a letter in front of that number though, which should tell you what model it is. (L, C, CC, etcIf it is a model "C", the serial number should be stamped on the engine block, on the driver's right side, close to the fuel tank, and just below the head. If it;s a Model "L", it is on the opposite side of the engine, toward the front of the tractor. In both cases, there should be a small area that has been machined smooth where they stamped the serial number.
Keep me posted on your progress. I love to talk Case!
Brian
03-11-2003 07:25:19
Brian
03-11-2003 07:24:54
