Fiber glass?
Kennyp
03-10-2003 13:11:52
Has any one used fiber glass to patch a frozen block? Friend just bought a S with a frozen block. Would fiber glass stand the heat/sunshine of hot water? We know about JB weld,if its done right. Crack is about 6 inches, extends down to curved part.Considering laying tractor on it side and do braseing right.
Tommy
03-12-2003 07:13:28
 Re: Fiber glass? in reply to Kennyp, 03-10-2003 13:11:52
Hey Kenny, I have a buddy that has really gotten good with cast iron rods. If you decide to do it right, check around and find someone that is experienced with welding cast iron because you can destroy the block. I'd try the cheap way first. You've got nothing to lose. I used JB weld on my truck block a few years ago and it worked fine hauling thousands of pounds of welding equipment in this Texas heat without failure. I ground a "V" (about 1/16 deep) the length of the crack (plus about 1/2 inch more past where the crack appears to stop) right down the middle of the crack. I wire brushed and ground everything clean about a 1/2 inch on both sides of the crack. This is the most important part. I put the first layer on so thin you couldn't tell anything was there, wire brushed it when dry and continued to put thin layers on after each was dry and wire brushed. After about 7 or 8 layers, the "V" was filled and it never failed. You might try it. Like I said, you've got nothing to lose. You can always get it welded.
Tommy
Mike
03-10-2003 16:03:23
hey, find a good welder, get some rods made for cast iron, take your time ,and fix the crack.My partner has fixed two blocks, with no leaks, or more cracks.
Kennyp
03-10-2003 16:37:58
 Re: Re: Fiber glass? in reply to Mike , 03-10-2003 16:03:23
Is there any danger of hurting the sleeve O-rings with the heat?
C. Amick
03-10-2003 14:16:59
Never heard of anyone using fiberglass. Most of the ones that I've seen were repaired with electric welds using cast iron rods. The J.B. Weld can be used to seal up the pin holes. Someone recently told me that the engine head repair shops use cast iron welding rods and melt them with a torch into the cracks?
Mike Schotte
03-10-2003 14:45:31
 Re: Re: Fiber glass? in reply to C. Amick, 03-10-2003 14:16:59
Myron,
Earl Seamands turned me onto this system which makes waterproof cracks in cast iron blocks and cylinder heads.
I haven't tried it yet- but it definitely looks interesting... just an updated version of the old way to "stitch" metal.
-Schotte
Don L.
03-12-2003 07:59:48
 Re: Re: Re: Fiber glass? in reply to Mike Schotte, 03-10-2003 14:45:31
I just pressure checked 4 different cyl heads that where stitched like that . They look ok , and you can tell where they did it, not a one would hold 30 lbs of test. Just went thru this last month. Don L.
