VAC Hydraulic Systems
Cliff
03-09-2003 22:08:45
Which system is more desirable? 1. The system that runs off the belt pulley drive on the torque tube just behind the starter? This system has been described as pre 1949 and was superseded by the eagle hitch.
2. The low pressure spur gear pump mounted and driven piggy back on the magneto. On distributor ignition tractors the pump is mounted in the former magneto opening.
When utilizing a three point hitch (non eagle) which system is best and least trouble free?
Thanks in advance. Cliff
BLR
03-10-2003 12:04:37
 Re: VAC Hydraulic Systems in reply to Cliff, 03-09-2003 22:08:45
You have much more flexibility with the cam driven low pressure system. I have a VA with a loader, live remotes, and the eagle hitch. All driven from the low pressure pump.
mj
03-10-2003 18:51:18
 Re: Re: VAC Hydraulic Systems in reply to BLR, 03-10-2003 12:04:37
I've got both and I also have 'hybrids' that utilize the low-pressure pump with multi-spool valve and a home-made 3-point. The Eagle hitch is good but, un-modified, does not give the flexibility that the Ferguson-style draft arms, with or without sway chains, do.
GeoMO
03-10-2003 05:31:11
My low pressure cam driven pump went bad and I replaced if with a 2 stage combine pump.
Best of both worlds, I use the one stage for the eagle hitch and the other for remote.
The cam driven is live power while the belt pump is controled with the clutch
