Installing hydrualics on D Case tractor from DC Case.
Ceder from Main
03-09-2003 13:22:23
I have the rear housing with lift arms and hydraulics from a DC case. Would that fit on a D case? Would a hydraulic pump from a old combine fit between the mag and the engine like it will on a DC? Thanks
DKase
03-09-2003 17:12:24
 Re: Installing hydrualics on D Case tractor from DC Case. in reply to Ceder from Maine, 03-09-2003 13:22:23
If you are refering to the cultivator lift arms it will interchange, unless one has live power and one doesn't, and if they are newer than 1941. If you are refering to the lift arms as an eagle hitch they will not interchange. As for the hyd. pump mounting on the mag. mount. That will work with a flange mount mag. Base mount it will not. We had one mounted like that on a 1941 SC to lift a mower and it worked OK, although it was really slow.
