Steering unit
mike
03-08-2003 10:47:39
I have a 12104wd that I replaced the seals in the steering unit 2years ago. With little use, it again is pumping hydraulic fluid up the steering shaft and out.These are Danfoss units. Is this a problem with the seals in the unit , the valve seal and spools, or just the seal at the top of the steering shaft? Does anyone know where I can find a used unit??
pieter
03-10-2003 00:56:35
 Re: Steering unit in reply to mike, 03-08-2003 10:47:39
Hello, you should ask elmer he knows and has a lot of db.
