DB 880 selectmatic
EFB
03-07-2003 19:16:41
Question for all you tractor haulers out there. I have a David Brown 880 selectmatic w/front end loader. I need to transport this tractor about 350 miles. I own a tandum axle trailer w/ 3500 lb axles,brakes and D rated tires. Trailer wieght 1800 lbs. I also am handicapped with a chevy 1/2 ton truck w/ 350 auto. Is this too much load for this trailer and truck? Any opinion would be appreciated. I will take these only as opinions. I hold no one responsible for my actions. Thanks for the help.
Eddie in KY
03-09-2003 19:18:56
 Re: DB 880 selectmatic in reply to EFB, 03-07-2003 19:16:41
I sold a Massey 50 to a fellow who hauled it 110 miles behind a Toyota Tacoma 2 wd p/u with a 4 cyl engine. The trailer had no brakes. I worried about him doing it as he had to go through several good size hills to get home.
James
03-07-2003 20:45:26
880 should only weigh about 4500 pounds. Guess 1000 lbs. for the loader, that's 5500 lbs. + 1800 for the trailer. Total 7300 lbs. No problem for the trailer with those tires. No problem for the truck if your hitch is sufficient.
Elmer
03-08-2003 04:40:28
 Re: Re: DB 880 selectmatic in reply to James, 03-07-2003 20:45:26
I agree it should be no problem. I have seen people do worse.
