VA Case Front tire size
Frank
03-05-2003 17:35:52
What is the right tire size for front wheels on a standard Case VA .Is it 550-16 or 600-16. Also front tire size for Case S and Case SC. Thanks Frank
Mike from Canada
03-06-2003 11:41:03
 Re: VA Case Front tire size in reply to Frank , 03-05-2003 17:35:52
if your VA has 16" rims on it, its probably a VAO. if the tractor has small 24" tires on the back its probably a VAI. Case used 6.00-16 tires on the front. all other front tires were 5.00-15.
good luck!
mike
Bill Hires
03-06-2003 05:03:21
The "VA" manual lists the front tire size as 6.00 - 16. They also list a 5.00 - 15 for the front tire size. I do not have the other tire sizes.
Jim
03-08-2003 16:40:46
 Re: Re: VA Case Front tire size in reply to Bill Hires, 03-06-2003 05:03:21
If it has cast iron front centers, it should have 5.00-15's, and if there pressed steel, they are 6.00-16's
