Case VAC with 9 bolt pressed steel 34 rims!!???!!
Pat
03-04-2003 14:13:27
Hello Case Fans, I saw a VAC the other day that had 34" pressed steel rear wheels, and was wondering if this was ever an option? Most of the ones I have seen have "star" shaped cast iron centers.
Thanks for any help, pat
CASEPOWER
03-04-2003 15:04:29
 Re: Case VAC with 9 bolt pressed steel 34 rims!!???!! in reply to Pat, 03-04-2003 14:13:27
No they were not a option, but massey 22 hubs fit right on and the 22s ran 34" rims..
Pat
03-04-2003 20:19:59
 Re: Re: Case VAC with 9 bolt pressed steel 34 rims!!???!! in reply to CASEPOWER, 03-04-2003 15:04:29
Thank You CASEPOWER,
I appriciate the info, do you happen to know the axle Dia. off hand?
Later, Pat
