Trailer load
Kennyp
03-04-2003 11:52:39
My friend has a flat bed rated at 7500 lbs. Tires are car type (load about 1900 each). Good solid frame. He has a Case 400 with a farm hand F11 loader.One ton Ford power strock is no problem. Question: will it handle it? I wonder if any of you have overloaded and how it went. I wouldn't hesitate on a short haul around a farm, but he need to run 150 miles of highway. I figure 6500 for the tractor plus maybe 1000 for the loader. Maybe a little more. I will not hold any one responsible :). We can't just run it on and look at the springs because wheels are too wide. Don't want to change them unless it will work.
Nat
03-06-2003 07:31:52
 Re: Trailer load in reply to Kennyp, 03-04-2003 11:52:39
I may have missread the post, but to me it looks like you will be way overloaded. 6500 tractor + 1500 loader + around 1500 trailer =9500 on a 7500 lbs trailer, way to much. most everyone else said it's OK maybe need better tires, I'd say the axles are way over, I hauled a 6500 lb bobcat on a friends trailer, he said it was 10800 lb cap. my son was following and stopped me, he said the axles were flexing bad. I checked the axles and they were dexter 3500 lb axles we offloaded and brought my 12000 lb, reloaded and no problem. I've never heard of 3750lb axles, they are probaly 3500lb and the wheel bearings on them are the weakest link, I'm not trying to run your biz, but hope you rethink the situation, luck, Nat
Ryan
03-07-2003 08:07:23
 Re: Re: Trailer load in reply to Nat, 03-06-2003 07:31:52
I would be very leery about hauling that load... we have a trailer very similar to what youre describing... hauled a new John Deere 250 skid loader home and that was about all the trailer could handle, skid loader wheighs about 6700lbs, but calculating tralier weight into things is also very important!
Dave_D
03-05-2003 14:51:04
The 7500 pound rating - is that the axle rating? That would mean the trailer would way about 1500 pounds. So your true load capacity is around 5000 pounds. I would recommend that at least one axle has brakes and a load leveling hitch.
Good luck, go slow at first and inspect the load after the first 5 to 10 miles.
- Dave
Slowpoke
03-05-2003 00:51:03
You didn't say which Case 400 your friend has. The 6722lbs is for the 403 Diesel High Clearance, and is the heaviest one of the 400 series. The lightest one is the 410 Special Gasoline Standard at 5626lbs, a considerable difference. The 400 Series (not "B") has 9 diesel and 6 gas tractors in the lineup. If the trailer is rated 7500lbs, you could get buy with the gas tractor, less the loader. Take the trailer empty to a scale and weigh it alone, off the truck. Then add that amount to the load weight. If it adds up to less than 7500lbs, your OK. If over then consider driving 35-40 mph on the highway. Back roads may be the answer.
Be sure the tires can carry the 7500lbs. Good Luck.
James
03-04-2003 17:17:55
Sounds to me like your tires are your weakest link! I would haul the load you are talking about, but not on car tires. You need to get trailer tires (at least 6 ply-C rated either bias or radial). You need to do everything you can to limit the possibility of a bumper-pull fish tailing.
Maybe you have never had that happen, but with a tractor strapped on is not the time to have it happen.
Fish tailing is also more likely to happen when too much weight is towards the rear of the trailer. Make sure you get it forwards to get a fair amount of weight on the truck.
Also, be sure the tags have been paid up to 12000 lbs. or you will be in trouble with the law.
James
03-04-2003 17:24:01
 Re: Re: Trailer load in reply to James, 03-04-2003 17:17:55
My price guide puts a 400 at 6722 lbs. (400 B at 3900lbs.)
L.lamp
03-04-2003 20:12:04
 Re: Re: Re: Trailer load in reply to James, 03-04-2003 17:24:01
I'm here to tell you I'm very lucky to post this note. BE CAREFUL!!! I had a neighbor haul home a '48 Chevy 2 ton with a 13 1/2 ft. grain box on a heavy duty trailer with a 4x4 Ford power stroke 4dr Pickup. We ran the front bumper right up to the front stop on the trailer and chained it down good. The rear wheels of the truck were about two feet back of the second trailer axle. Looked like plenty of weight on the front. We were on a gravel road starting to take a run for the next hill. When we got over 40mph that trailer tried to tell the rear end of that pickup where to go. We went back and forth about five times before control was recovered the second and third whip just about ran us out of steering. We decided that was a fluke because we were on gravel, it wasn't. It did the same thing on the pavement. We went 35mph for the next 55 miles. This was a bumper hitch trailer. A gooseneck maybe wouldn't have done that. Another guy with us said he hauled 17,000 pounds of blocks with it a week earlier going 70mph down the interstate. He has to be certifiable!!! We thought we were safe. Watch your speed because once it starts to whip you are just along for the ride. Take a roll of TP it might come in handy.
kydavid
03-04-2003 16:36:13
If you weight estimate is correct I'd say you are just in the maximum weight for the trailer, with really good rubber. For a 7500 pound rating I'm guessing either 1 7500# axle or 2 3750's. I'd try it if its a gooseneck with 2 axles, if it's a bumper hitch probably not.
That said the truck should be no problem. I regularly run up in the high 20,000's on my 3/4 ton Dodge. I do try to keep my payloads withing the axle rating on the trailer, still overloaded but only by the weight of the trailer.
Kennyp
03-04-2003 17:07:31
 Re: Re: Trailer load in reply to kydavid, 03-04-2003 16:36:13
Thanks for the comments David. When it quits snowing I am going to measure the tandem axles. I have a catalog that gives dimensions. Probably 2-3500lb. Just in case they are heavyer. If they are, better wheels are in order, and would solve the problem. Its bumper pull, but probably could stand 1000lbs on the hitch. It just pulled 100 bales of hay,about 6500lbs, Colorado to Oklamoma and never even twitched.
