Case steering problems
Brian Matheson
09-26-2006 12:19:37
I am looking for the verticle steering gear (more specifically need the 3 hardened steel pins) for my Case backhoe. I can not find a tractor model number but the loader # is 4051327 (1960). I have looked at some case parts books and I believe the part # is G13287 (320 or 420B). The tractor has CK stickers but it did not match with pictures from the book (it has a more rounded front around the lights area). If you can help with finding the 3 hardened pins (they appeared pressed in, or the gear) that would be great. Also, if you have an idea on where else to look for the tractor model number I would appreciate that as well.
Thanks.
Brian
Don Livingston
09-27-2006 05:11:31
 Re: Case steering problems in reply to Brian Matheson, 09-26-2006 12:19:37
Press out the 3 pins and "turn them around". They only hit on one side. If they are loose in the hole, I have new .005 oversize pins.
Don L.
