What motor is it?
Gene
03-03-2003 19:01:40
A friend has a Case Tractor there are no Ser.#'s on dash. We are doing an engine overhaul. We though it was a 400 because we had a 12inch clutch in it. The crankshaft has the number for a 400, the camshaft has a number for a 700 and the water pump number is for a 700. The engine block has a number on the rightside, center 4600A, on the leftside but by the flywheel has a number
640 3. The piston are 4inch with 4 rings. Has two
heads. What model, year,engine do we have? Thank you.
Dale in Tx.
03-03-2003 20:03:01
 Re: What motor is it? in reply to Gene, 03-03-2003 19:01:40
When the leaver is complety down the triger has to be tripped to engage,Down is off up to engage but it is better to leave it engaged when not in use because it will slip and when you get ready to use it you have to adjust it, after a while you have to replace the cluch plates. The 400 gas and 400 diesel block are the same,sorry about the double post Dale in Tx.
Dale in Tx.
03-03-2003 19:39:44
Gene that is not a block out of a 400 book says 4900AA is the block no.for "400"Powrdyne gas engine.Must be a 700 they had 4" pistons also block should have more no.s on left rear flang of block. 700 tractor had headlights in hood also had lock on PTO also instruments were in cluster on dash. The sleeves have a larger flange on top afew more changes 12 volts for one. Hope this helps Dale in Tx.
Gene
03-04-2003 20:30:55
 Re: Re: What motor is it? in reply to Dale in Tx., 03-03-2003 19:39:44
Dale in Tx, I missed typed the Nu. from the Case block it should have been 6400A.
Dale in Tx.
03-03-2003 19:37:03
Gene
03-03-2003 19:43:39
 Re: Re: What motor is it? in reply to Dale in Tx., 03-03-2003 19:37:03
It does have 12 volt, lights have been changed to inside the front grill. How does the lock work on PTO.
John Saeli
03-03-2003 19:20:18
Gene; If I remember correctly you are working on a gas engine. It's the 251 gas. I think the "400" and "700" used the same engine. I know they both were the "251" but I'm not sure if the later "700" engine had any differences, I don't think so. I think they both used a 12" clutch. The grills are different for the 2 tractors. Is the grill intact? How far are you going with the overhaul? John
Gene
03-04-2003 20:34:06
 Re: Re: What motor is it? in reply to John Saeli, 03-03-2003 19:20:18
John Saeli, I missed typed the engine block number, it should have read 6400A. Still cleaning it up and getting ready to put it back together.
gene
03-03-2003 20:01:05
Well we put in a new clutch,pressure plate and throw bearing and changed the ring around for the starter. Then after we put it back together oil blowing out of exhaust pipe. So split it again and are now doing complete overhaul, sleeves,pistons,bearing and having the crankshaft ground. The camshaft is ok but new bearing for itand he is having an engine repair shop do the heads. While we are working on his we are also working on mine, I have a Oliver Super 55. Its a little smaller then his. Yes it is a gas engine. The grill on this tractor is kind of flat, I wouldn't say round, I don't know how to describe it any better than that. It seems to us that it must have been an orchard tractor, because it has a very low profile.I want to thank you for all the info.
