PTO driven hydraulics
dbb62
03-03-2003 14:37:42
I want to add remote hydraulics to make our old Case's more useful. I have seen several PTO driven units on old tractors, but don't know where to get one.
Do they still make these? Can someone tell me where to get one?
Thanks
Joe (Wa)
03-04-2003 23:22:21
 Re: PTO driven hydraulics in reply to dbb62, 03-03-2003 14:37:42
You may want to consider one of these Prince pto pumps. I've been running a 3.0 backhoe off one for several years. There are internally splined all the way thru so you can run an implement piggyback off it.
Link
dbb62
03-05-2003 09:06:25
 Re: Re: PTO driven hydraulics in reply to Joe (Wa), 03-04-2003 23:22:21
Looks like this may be just what we need. Thanks.
C. Amick
03-04-2003 09:54:54
I think I saw a PTO mounted hydraulic pump in the V.B. catalog. I am putting a hydraulic pump on a 1949 SC right now. I wanted to still be able to use my PTO for other purposes, so I am running it off the chain driven gear that is inside the housing below the PTO shaft. I had to make a new housing cover plate to mount the pump to. I intend to run a hydraulic post driver with it. I can send send photos, when it is finished, if interested.
Jerry
03-03-2003 15:21:31
dbb62, Need to know what Case tractor you have and then maybe we can help you.More than likely you can buy a unit from Don Livingston and it will fit right in.
Jerry
dbb62
03-03-2003 15:40:52
 Re: Re: PTO driven hydraulics in reply to Jerry, 03-03-2003 15:21:31
We have a 49 model D, and I am buying a 48 model S. Both standard models, not DC's and SC's.
Jerry
03-03-2003 15:21:12
Jerry
